PTT component, what's it called???
skynyrdcat
Got an 86 Searay cuddy cabin...
Mercruiser 4cyl in board (B407574) TRANSOM ASSEMBLY # OB423625
Doing some work on the power trim and discovered that the small pc (I'll call it a coupler) that connects the motor shaft to the pump shaft was cracked.
Been trying to look one up to purchase but not sure what it's called.
All help or links to find one will be greatly appreciated.
HT32BSX115
Re: PTT component, what's it called???
Well I went to Doug Russells parts site. There's 3 or 4 different pumps for that year.
Click HERE
It's a crummy picture,
You need #2 below? It's called a "coupling"
You might go to their site and determine which model you have. You can order it right off their site. ANY parts dealer that sells Mercury parts can get it if it's available.
Cheers,
Rick
