z1nonlyone
Thread starter- Joined
- Apr 20, 2010
- 58
Hey, so I got a call last night from the buddy whos water pump impeller I changed 3 weeks ago and said that outdrive oil is leaking out of the water intake holes (where you attach the muffs) and has made a paper plate sized puddle on his garage floor! He has a 3.0lx and alpha 1 gen 2 drive with only about 100 hours or less.
I changed the waterpump and seals, quad ring, shift shaft seal and related orings etc. The kit I bought did not come with the Seal Carrier thats located right under the water pump. It is about 2" in diameter and has one large oring and two lip seals that ride on the driveshaft. I reused the old one.
When the shift shaft seal leaks, I think it drains out the two little holes by the mounting bolt. So I don't think it is that.
Could it be leaking under the water pump and coming up and over the the large water cavity? Or could I have disturbed something in the upper unit and the oil is leaking down to the water cavity?
My buddy is a big guy and not mechanical. I will need to go fix this for him. He lives 3 hours from my house and I want to arrive with the correct parts!
Anyone with expericane as to where the oil is coming from?
