Do you mean you pulled it off and you now have no gears ? Can’t quite get what you mean from the above. If that’s what you mean, did you connect up the selector mid shaft again ?
Sorry. I pulled the bottom end off to change the impeller. put it all back together. Boat went in the water today. Started first pull but when I shifted it in to forward (shifter is on the handle) it was in revers. Then I put it in reverse and it was also reverse. That make sense?
Ok. Got you now. Not totally familiar with this particular engine but is there a access hole half way down the shaft casing to access the linkage that you had to undo
