Joshua Nichols
Thread starter- Joined
- Jun 29, 2009
- 1,431
So after finally getting the engine running good.. I noticed a vibration.. Pulled the outdrive and yucky.. Grease (not gear lube) and water in the bellows.. I found the little ring hanging on my drive shaft.. Is it the backing to the gimble bearing? There was a ton of green grease in there.. Previous owner musta pumped a gallon in this thing. I was also wondering.. How you get the bearing out? Slide hammer or something? The bellows looked okay, but low and behold a little cut at the top.. Check out how deformed it is.. I guess that's from the guy leaving up for so long(trim motor was out).. I don't think I need to replace the u joints.. They seem pretty smooth.. I think I caught the trouble early.. Another thing. The nylon nuts sure came off easy.. Those should be replaced too I think..
This outdrive is so easy to get off.. No wonder it should be seasonal maintenance. Used a piece of wood and the trailer jack to help get it off.. Sure made the difference.. I am a strong fellow, but I don't wanta make a habit of picking the thing up.
