Jeepster04
Thread starter- Joined
- Jan 5, 2009
- 481
The plan is to pull our boat out of the water this March. This is typically done for 1 day once every 4-5 years so all parts need to be on hand the day we pull it out of the water. The boat has dual Volvo 5.0's with DP-A outdrives. We will have a Marine Tech there that will be working on the boat but Im going to be buying all the parts. First things first, the starboard out drive has some water in it. We ran the boat for awhile then pulled the dip stick and it was slightly gray(port O/D was fine). No water has been leaking into the boat and there are no noises from bearings so Im assuming theres no holes in the bellows. I would like to buy a complete seal kit for both O/D's that covers everything. Input seals where the shaft goes in, seals for the props, seals for the dip stick and fill plug, seals for the upper end when we take the top off to get the bellows off, every seal that is on those O/D's I want on hand. We will be pressure testing the O/D's prior to filling them back up with oil. Pretty sure the alignment will be checked but Ill make sure.
Just a quick list:
-At least 4 u joints just in case
-U Joint bellows
-Exhaust Bellows
-Oil
-Seal kits for both O/D's
-Anodes for the prop shaft and transom on both O/D's(Port anode was fine but starboard was almost 50% gone)
-Should we have the elbows that sit on top of the O/D's for the water intake on hand?
-What type of hose goes from the elbow to the transom for the water intake? Should that be replaced?
-Ive looked through the manual and cant tell how the shift cable goes into the boat. It doesnt appear to have a shift boot. Anything needed for that?
Anything else? Ill be going with Volvo Bellows for both the U-joints and Exhaust. Would like to get the seal kits from Volvo also. Probably get the U joints at napa so I can take those back if we dont need them.
They call this kit a Complete gasket. Looks like that would cover everything on the O/D, right?
http://www.volvopentastore.com/Repa...--store_id.366--view_id.329597--viewcart.long
4100113751
Just a quick list:
-U Joint bellows
-Exhaust Bellows
-Oil
4100113751
