Pulling my 87 5.7 mercruiser engine
Lwarden
I am getting ready to pull my engine this weekend to do a complete transom rebuild, are there any tricks or special info I need to know before pulling? Not the first engine Ive pulled but yes my first boat engine, just want to be sure Im not gonna mess up anything...Thanks for the help...Lee
JASinIL2006
Re: Pulling my 87 5.7 mercruiser engine
Label everything and take lots of pictures!
Good luck!
FreeBeeTony
make sure you pull the drive first........:)
Lwarden
Thats the kind of stuff Im talkin bout fellas!!! Thanks for the insight!
Ayuh,... Ditto that,... 'n pull the front mount lag bolts, not the adjustin' nuts...
Lwarden
Ok! getting close to pulling my engine, here's my pre engine pull list, if you guys notice anything I didnt disconnect but need to please chime in.
Removed the out drive.
removed the fuel line
removed the 4 lag bolts from the motor mounts
removed the 2 long bolts that hold the engine to the transom housing
removed the water coolant hose from the transom housing
loosened the screw clamps from the y pipe to the engine
disconnected the alternator to battery cable
disconnected the trim sensor wires from the engine
disconnected the starter cable
diconnected the shift cables and throttle cable
disconnected the ground wires
disconnected the power steering lines
disconected the ignition plug from the engine.
I think thats everything?
Don S
Lift it up, if you find anything still connected, take it off.
Zraden
You forgot a few things. Ill update your list for you.
Crack a beer
Crack a beer
Crack a beer
disconnected the shift cables and throttle cable
disconnected the ignition plug from the engine.
Crack a beer. Put engine on stand. High five and breath sigh of relief.
Lwarden
Zraden, thats awesome! hate to say it but beers are implied! and thanks...
Don S
Crack a beer X 3
Usually followed by a thread titled "Just worked on my engine and it won't start"
Lwarden
I did find one of the motor mount lags to be stripped, hoping the mount isnt rotted. Ill drill some holes once the engine is out.
Zraden
LMAO Dam I forgot.. its engine "removal".. so actually its more like crack a beer x8
Helps ease the sting when you find things like rotten stringers and rusty bolts along the way.
