Re: pulling wire off #3 plug
The trigger wires are in pairs, one pair for each cylinder. Disconnect one of the wires of the pairs from the terminal block say for #3 cylinder. It's important to disconnect one of the wires to eliminate other components that may be in the circuit that will affect your readings. Put you meter on the X1 scale for ohm's. Put one lead one the wire for #3 on the terminal block, and the other on the free end. It should read around 54 ohms. After checking, reconnect loose wire to terminal block.
Check the stator wires in exactly the same way. They should read somewhere between 680 and 850 ohms between the blue and yellow or brown/yellow and brown/blue wires depending on year motor you have.
