goblerblaster
- Joined
- Dec 26, 2011
- 180
My Clymer repair manual says to change out the pulse limiter if you replace the VRO, but does not say why that is needed. If you take off the VRO to repair the fuel side, can you continue to use the existing Pulse Limiter ? Is it just a "good idea" to replace it or is it a "must do" ?
Also, the manual has a picture of the VRO and says to "never seperate these parts". The picture is of the oil pump and the electrical input that connects to the oil pump. I need to do just that coz I have one VRO that the oil pump works but not the gas pump, and another that the gas works but not the oil. Any problems combining the two?
I am about sick of messing with the VRO on this motor. Is there any way to just put some type of electric fuel pump from Autozone on it, premix the gas and oil to 50-1, and be done with it?
