pump housing,impeller & key
isis
On a scale of 1 thru 10, 10 being the worst. How does the parts look? I have all new coming but was not sure if the key is made with a tamper edge that the impeller slide on or it is made like that?
Frank Acampora
Re: pump housing,impeller & key
The pump housing is shot, the impeller is unuseable (unless you like to be towed into port), but the key is reusable. They all get a slight "wear" mark form riding against the shaft slot and impeller.
With your pump body in that bad condition, check the walls of the lower plate that seals the lower unit. If the walls are corroded to the point where the stainless plate and gasket below the pump will not seal them, then it is time to replace it and the drive shaft seal too.
isis
Looks good to me but i no expect?
