Re: Purchasing new boat, need advice.
Astewart, The boat looks pretty clean and the price seems good. Due to its lack of bottom paint,I will assume it was run in a lake or trailered, which also is a plus.<br /><br />The oil leak (if it is oil) is unusual, since it is not coming from the outdrive. It appears to come from the bilge of the boat via the drainplug. It is likely power trim fluid or power steering fluid or engine oil. You should look for the source of the leak. Replacement hoses for the power trim system are $50 each, power steering hoses $125/set.<br /><br />The boat itself is a good choice for all around family fun. You will be able to fish and water ski. It will prove to be a bit under powered with the 4 cylinder motor, however. Expect 35-38MPH as top speed. Also, it will prove to be a bit small in the interior, since a 17 footer is small to have a sterndrive motor. It will prove to be good on gas, but periodic maintenance is high on a sterndrive, and very high ($1000/year) if you have it professionally maintained. Repairs will also need to be made, in addition to periodic maintenance.<br /><br />You can certainly put a captains chair in front. It may cut down on the interior space, and eliminate one seat, however it is done frequently. You will need to use some anchor-type fasteners to hold the chair in place!
