Push Rod Cover Oil Leak
morebacon
Hi folks, I'm dealing with an oil leak at the bottom of the push rod cover for a 3.0L. I've replaced the cover gasket (with a cork one) and that fixed the leak around the cover.
But now I have oil leaking around 2 of the bolts. Any suggestions on how to deal with that? I'm afraid of over tightening them and bend the cover. Thanks!
morebacon
So it seems there should have been some o-rings on those bolts (part #25-25429). I've used some that I had around until I get the correct size and the leak seems to have stopped.
johnboy68
I have the exact same problem, but it doesn’t appear the OEM were o-rings. Are you sure that part # is correct?
kenny nunez
An old mechanic‘s trick. Back the bolt out about 1-2 turns, wrap the underside of the bolt head with kite string then tighten.
