Putting a tiller handle on a mid 70's Evinrude 25hp
doors67us
Hey guys , wondering how hard it'd be to install a tiller handle on a 25 Evinrude,that has remote steering,do you have to change the stern bracket or? thinking of purchasing this said engine
Honorary Supreme Mariner
Be a lot easier if we knew the exact model # of the engine.----There may be options depending on model #
brodmann
Older motors had a tiller handle that had gears and linkages. Newer motors have cables that go from the tiller handle to the linkages on the other side of the motor. We'll need to know as much as you can tell us about the motor (as mentioned above) I recently purchased a newer 9.9 mercury that was made to be controlled remotely. It has a tiller handle, but the tiller handle does nothing but steer the boat. It has electric start, but no starter button, just a harness that goes to a control box. The tiller handle twists, but that does nothing, since the cables to shift/throttle were connected to a control box. so, if I want to use it as a standard tiller handle model. I have to purchase the cables that go from tiller handle to the linkages on the motor, and I have to replace the harness with a starter button, and I need to order a "plug" to cover up the opening in the lower cowling where the shift/throttle cables were run from the control box to the motor. So, I need to spend about $100 that I didn't expect to make this motor work like an "old school" standard tiller handle motor. Just letting you learn from my mistake.
doors67us
There's the model number hopefully that'll help, wondering what the spread on tiller handle would fit? Like from 1960-1975? Horsepower from so to so ?
airshot
If already setup for remote, why not add remote to the boat...probably same cost and effort... My personal opinion is remote is much easier to manipulate the boat...
jimmbo
I thought all 18/20/25 motors in 1971 came with Tiller Arms
