I have an '03 Ford extended cab with a V6 and the factory towing package. 2 inch receiver, 7 pin flat , round plug, and the standard 4 pin flat plug , all standard factory options. My question is this, I put a 3,000 lb. ATV winch on the trailer making the brackets and all that , then set a car battery on the trailer to "try the wench out" . Things seem to be working ok to normal. Now I am wondering how long that one battery will last pulling the boat up ( 15 foot trihull fiberglass with 70 hp johnson motor. On the 7 pin round plug on the P.U. I see a + and - plus the tail, park, and brake lights. My owners book says there is a hot wire constant in that plug but I can't find it with a test light. Can I hook a hot wire from the Pick up to the spare battery to "charge it " on the way to the lake or will that overload the electrical system on the pick up ? Or , if I do find the "hot wire" on the pick up, what type of fuse, breaker or ? would I have to put on to handle the winch? Supposedly its marked as 12 V 120 amps. intermitant use. If anyone has done this thing before I would like to hear the outcome of their experiences and if it works.
