Gradywhite3535
Thread starter- Joined
- Dec 29, 2012
- 480
I have a 2003 yamaha 130 txrb.I had to replace my water pump impeller. Iam going to be putting the lower unit back on tomorrow but have a quick question. Right now the boat is in neutral and the lower unit is in neutral. I wanted it to be in gear just in case the drive shaft doesn't line up I could turn the prop a little. Can I put the boat in reverse or forward at the helm and then put the lower unit in F or R? Which one would be better and on the lower unit shifter do I turn it or pull it up or push down? Thank you
