alright, i pulled the carb off to clean and install the kit. that went fine, but I am running into a couple of problems putting it all back together.
first off i cant figure out how the manual rope start component goes back on there, which is sad because it only has 1 bolt holding it in. i dont remember which way it was sitting when i took it off. can anyone help me out in this area.
i was going to try again to get the flywheel off to assist me in getting the manual start component back on, but unsuccessful again. i tightened it as much as i could and whacked it good on top of the puller bolt with no luck. its now sitting with some penetrating spray on it. i will try again tomorrow.
the main thing i want to do is get that manual rope part back on so i can put it back together and test the motor.
also, is there supposed to be a washer on the bottom of the manual start recoil?
thanks
thanks
