q-jet linkage issue
biddle1950
'85 bayliner 1950 capri
350 omc stringer
the linkage on the starboard side seems to be stopping throttle linkage. there is a spot where the secondaries will open, but when it warms up, it's like it goes too far and stops the travel again. I watched many times and cant figure it out.
It seems like it is there to keep the secondaries from opening on a cold motor.
Some jeep guys say to remove the part.
also I replaced the carb to intake gasket with one thicker than the one that came off for fear of sucking air.
anyone else had this problem?
thank you.
cr2k
Re: q-jet linkage issue
This is a MARINE carb right? if not no answer from a lot of ppl due to liability.
Pictures will help a lot, as there are several linkages on this carb.
Aloysius
The linkage for the secondaries is on the port side. There are usually linkages for the air valve on the starboard side.
Quadrajets should use a 1/2" thick base gasket..comes in the jiffy kits during a rebuild.
biddle1950
Yes it is a marine carb. original to the boat.
the linkage is on the side with the choke spring.
