qd-15 with weak spark on top cylinder
ferd66
Hi Guys,
I just picked up a qd-15 in a boat, trailer, motor package deal. Guy said the motor ran but needed a tune-up. Because of the package price($350), I bought it without checking the motor over real well. Brought it home, it appeared to have no spark on the top cylinder. I then used an air gap tester and found that the top had spark, its just not as bright as the bottom cylinder. Changed points, condenser, and coil and it made no difference. Only thing I haven't changed yet is the plug wire. Would that make the difference?
I put it on the boat and ran it tonight on the lake. Seems to run fantastic. Idles at 1.3mph and tops out at 20.7 on gps. Quite surprised by the performance.
Daviet
Re: qd-15 with weak spark on top cylinder
If it aint broke, quit try'n to fix it.
What distance did you have the tester set at?
bktheking
Sounds like it's on par, what boat, my qd-12 did 18 on my 14 ft crestliner aluminum.
bktheking
Runs like a champ, if it were down on spark you'd know it.
1946Zephyr
Hi Guys,
Spark plug wires can make a HUGE difference and so will how good the coils are mounted. The coils have to be mounted to where the face matches up the machined area on the mag plate perfectly, or they may not deliver the right spark (or not at all.) I usually replace the wires, when I replace the coils, just to make sure that I'll have the longevity.
