Re: QD 20 and QD 21
Thanks for the Email ...
I have put the QD-14 on hold due to some problems .. 2 dead coils no problems there ..
the prop seems to be bad and kitting the seal and there are 2 nice dings in the seal on the prop shaft so that put a wait and see what I am getting into mode
I had a dq 21 in parts ( big basket case) given to me a number of years ago but no boat for it .. I was given 2 boats so fix;n one up and traded the 2nd for a qd-20
the qd-20 would not shift right .. so I look at the QD-21 and hay I can put the motor from the qd20 into the DQ-21 .. and see whats going on with the shifting of the QD-20 .. and now I have a working motor !!! and it ****s !!
now the problem with the QD-20 shifting was under the motor .. the joint thats under the motor was CRAP .. lots and lots of play and would not allow the shifter to work right .. and the carbon !!! HOLY CRAP 20 min to remove the crap from the bottom of the motor , it was a good thing I have a new base gasket from the basket case ..
next is to find a carb rebuild kit
I have been reading a lot of posts from other users .. THANKS FOR ALL THE INFO !!
I wish I would have found this site a number of years ago when I was working on my 1970 ES40 (if I remember right) 40 HP with E. shift ! what a solid motor ! just toss a belt every now and again
