QD-21 10HP johnson
stingertrey
Re: QD-21 10HP johnson
what kind of square pump are you reffering to.. could you send me a link of a place to buy one? and to replace the impeller on this motor do I take the little oval plate on the side of the leg off to get to the shift linkage? I crunk it up tonight on the 2nd pull.. didnt pump water so I shut it down. Gonna replace the impeller with the kit I got with it
bktheking
Have a look at the pump
http://www.iboats.com/Evinrude_Fuel_Pumps/dm/*******.114422291--**********.900343967--view_id.269718
You can see the motor, I can't even find a pic online of the motor with the hood off. Line size and room to mount is the important part. They are all pulse pumps and the gasket appears to be the same on all, it's just a matter of what you think will work. 18-7351 looks like the best fit, it's the later 9.9-15 hp pump. If it's got the oval plate, pull it off and look, chances are it's the shift rod access.
