Mauro Brisola
Thread starter- Joined
- Jun 13, 2016
- 31
Trying to help a friend.
2010 QSD 2.8 with Bravo 3 X drive. Engine, drive, gimbal were removed to replace upper swivel shaft. After that there was some damage to 3 wire drive trim sender. After service trim gauge did not work well and engine limited to 3000 rpm when testing boat on water. No Smartcraft alarm.
Mechanic assembled a new 3 wire trim sender. PN 8M0107462. He tried several times to adjust/set sender. But up to now system does not work well. Despite drive trim works, the final course, when usually trim goes to final stop (indication above 10 on trim gauge), does not work. And engine speed limited to 3000 rpm.
I searched for some wiring diagram to discover where each of the 3 sender wires goes, But find nothing about in the Internet. Idea is to use a multimeter to undestand what's wrong with sender.
Another question is if in this case a trim sender problem could explain the engine speed limitation to 3000 rpm. There is some link between drive trim sender and engine control?
Thanks in advance.
Thanks in advance.
