wilyesteve
- Joined
- Mar 10, 2011
- 38
I have been trying to tune my rebuilt 5.7... still only maxing out at 4100rpm according to the tach, and cold starting is not easy. Bought a rebuilt carb while I was at it too.
Idle is around 900rpm. Carb seems to like its idle mixture screws about 5 turns out.
If I try to lower the idle with the idle speed adjustment screw, I will get a whistling sound when I get the screw to a certain spot.... is this normal? Doesn't seem like it. The fact that the whistling is dependent on the throttle blades makes me think the air is NOT leaking around the intake or carb base, but rather within the carb. Carb cleaner spray around manifold or carb base does not indicate any leakage.
Any ideas?
Any ideas?
