Quadrajet question
autotec
I finally pulled my carb apart for a quick cleaning, and I noticed something. The carb doesn't have the secondary well tubes, and it doesn't look like they were ever in there. Doing some research, I have found one guy who said some marine carbs came without them, but it wasn't all that common. Has anyone else ever seen that? The carb is off of a 1988 OMC 350, Quadrajet # 17059286.
It just took me by surprise. I've had hundreds of these apart in the automotive application, and they all have had them.
Thanks,
Justin
autotec
No Title
Just a small update on this:
After a few hours of research, (when I should have been working) I found a bunch of cases where they didn't use the secondary well tubes. Even if I did decided to add them, the air horn and main body was never machined to accept them. So I decided to go ahead with the rebuild without them. Below is a picture fresh out of the ultrasonic vapor bath. Lets see if we can fix the slight bog at WOT.
Howard Sterndrive
I always find I have to really tension up that spring adjustment for the secondary air valve to get rid of the hesitation/lag going TO wot on any boat I have owned with a Qjet.
Walt T
The slight bog at wide open is the secondary restrictor plate adjustment.
autotec
No Title
Thanks for the info guys, the boat starts, runs and idles great now. Now onto the other issues.....
Thanks again, Justin
