Question 0n 95' 115 Yamaha
MAKO72
I have a new to me 1995 Yamaha c115. When idleing through flats with the engine trimmed up (not to high still good water flow through pee hole) the engine will stahl and will only start again if I choke the engine. Any thoughts? I was thinking maybe fuel pump?
Dunaruna
Re: Question 0n 95' 115 Yamaha
Your description would indicate that the motor does not stall when trimmed all the way down, is that correct?
MAKO72
Correct only stahls (sometimes) when idleing tilted and requires choke to restart
Dunaruna
It is starving of fuel, probably a needle/seat issue. You need to check the fuel system and test for correct fuel pressure, leaks, hard primer bulb etc. Rebuilding the carbs is pretty much a given.
