question about 350 chevy wireing
zimmynn
i have a 89 350 260 hp merc crusier i cant get it to start, there is a wire that comes off the main bundel with a green and white wire that goes to the distributer, i can not find this wire on the wireing scematic and have no idea where its suppose to connect to it has a ring connector on the end and is off white with blue spirel line on it if any one can tell me where this wire connects or if it's just a stray wire it has like 5.8 volts on it when the ignition is on. i replaced the parts in the dist. but don't remeber disconnecting the wire so if any one can help i would apreciate it thanks jim sorry i had the wire color wron its an off white or faded light tan with a blue spirl strip and is in the same harness as the white with green strip going to interupter switch thanks
Haut Medoc
Re: question about 350 chevy wireing
HMMMMMM.....
The white/green usually goes from the ignition amplifier to the distributer.....
Then to the shift interrupter switch by way of the terminal block with the gray & black wires that connect to the above mentioned switch....
Welcome to iboats, btw.......:)​
zimmynn
HMMMMMM.....
admirl i ooked at the wire again and its like an off white or fadded tan with a blue spirl stripe on it and it is in the same hartn3ess as the green strip on white wire that goes t the shift interupter switch thanks for the input i had th e wron color on the wire any more info would be appreciated
Don S
The tan/blue wires go to the alarm switches. Either temp, oil pressure, or both.
zimmynn
thanks don this wire is back by the oil pressure sender so guess thats where it should connect and would this keep it from starting thanks jim :)
