First off, I think I figured out the connections for the control cables but I'm posting a pic of that area and tell me if I'm wrong but the mercury cable should just go over the threaded stud and is held on with a nut, I don't think there is any other connector or part needed, I should have pulled the gas line as I ran it straight to the pump to test run the motor so it is kinda in the way. Second, the serial number is illegible and need to know if there is a number anywhere else like stamped on the block or something, I can't see one but maybe I'm looking in the wrong place And last, I started the motor, it ran smooth but I saw no water coming out anyehere so after about 20 seconds I stopped it. Now on my Johnson 48spl it would start peeing in about 3 or 4 seconds. Anyone know if the force 70 hp is about the same? According to the place I got it from it all worked fine and of course I'm ordering a new impeller but just want to be sure I know what I'm looking for.
Thanks for the help
Thanks for the help
