Re: Question about boat electrical system
One more time: There are two types of ground (negative) connections that can be incorporated into a switch panel. Obviously you run a large gauge red wire (positive) to the switch panel because it is what feeds all of the switches. Some switch panels have a ground BUSS built into them so all ground (negative) wires from accessories can connect there and you would NOT need a buss BAR because the switch panel has one. You can tell if it is intended to be used as a buss because there will be several NEGATIVE attachment points. If there is only one negative connection, that is NOT a buss connection -- but rather a ground connection for the internal LEDs on the switches. You don't need a 10 gauge wire for that connection because the only current it carries is for the LEDs. So NO! You do not run heavy wire in that scenario to the switch panel THEN to the buss bar. If you must use a buss bar then the the large gauge wire runs directly from the battery to the BUSS BAR. The negative connection from the switch panel goes to the buss bar but again, using 16 gauge wire. But here's a thought -- why not decide on a switch panel and then post a link so we can stop guessing.
Here is a fuse panel with a built-in NEGATIVE BUSS. A switch panel with one would look similar.
Here is a typical "Boat/Helm" wiring diagram. You can use a master cutoff or not. It is purely optional.
Here is a switch panel with lighted switches. See the small black wire at each switch. That's the ground for the internal LED. There is no BUSS connection on that panel. That small wire goes TO the negative buss.
