Question about compression
Emerger
I hope this is in the right forum.
Is cylinder compression universal among outboards, or how much does it vary from manufacturer, type, etc.? Does anyone know of a comprehensive list of cylinder compressions for different outboards? I see a lot of ads for used outboards stating compression of XX in each cylider, but it's difficult to tell if it's good, bad, or indifferent. Thanks.
Paul Moir
Re: Question about compression
Johnson and Evinrude never published any compression specs to the best of my knowlege. For older outboards they said all cylinders must be within 10% of each other. I think on some later ones they extended it to 15%.
There was a reason for this. The only thing that varies as much as compression testers themselves are the methods employed when taking a reading. Hot, cold, number of compression strokes, how fast it's cranked, altitude, how much residual oil is in the cylinder all have major affects. Even throttle position and barometric pressure make for a slight change. (Although admittedly you would need to be taking the compression test during a hurricane for it to make more than a psi or two of difference. )
And to make matters even worse, you can not even compare similair outboards. The big V6 J/E engines tested new around 120 psi some years and around 80 psi other years. Even a slight change in port timing has a dramatic affect on "static" compression.
Emerger
Thanks for the help. I understood that the compression should be equal (+/- %) among the cylinders, but I've seen equal compression advertised from 80 to 155 psi.
Again, thanks for clarifying.
steelespike
Generally speaking you look for at least 100 PSI and within 10% cylinder to cylinder.For some reason some manufacturers don't release their numbers just the 10%
figure.I've found tune up figures from 115 to 165 psi.
I would say generally that newer smaller motors 7-50 hp would be in the range of 100-140psi.And larger motors in the range of 125-170 PSI.And it is important to be even cylinder to cylinder.I've seen smaller old timers run fine at 60 PSI.
tashasdaddy
agree with Spike. the closer they are the better they run.
