Question About Exhaust
beninlou
I Have A 93 Kawasaki Ts 650 The Problem Is When Running The Ski There Is Alot Of Oil Coming Out The Exhaust.is This A Major Problem Or I Thought About Taking The Oil Injectio Off And Mixing My Own Oil.any Help Would Be Great Thanks Ben.
Camlocker
Re: Question About Exhaust
Oil coming out the exhaust.....have you checked the plugs? If you have that much blowby, I would suspect your topend is toast or possibly a hole in a piston. I assume it runs, but do a compression check. If everthing tests ok, then put some fresh plugs in and check your low speed jetting. If its pumping too much oil and not enough gas, this can do what you're describing, but fouling plugs like crazy.
You mentioned blocking off the oil injection. I did this right after I bought my Sharks and now I premix 40:1 with Pennzoil Premium Plus. For older skis, they recommend this since the injection can burn up an engine if it decides to go south on you.
Hope everything turns out ok.
Jeff Walkowiak
that is normal ,oil collects in the water box it comes out black,, wash out the excess oil by pulling off the hose that goes in the muffler pour in some dish soap and fill the muffler with some water, let it sit for 30 min and then run the engine on the hose for 5 min, the mess will be obvious so don't do it on a driveway .
