BillWilliams
Thread starter- Joined
- May 23, 2021
- 79
My serial number is 0L440964.
I have service manual number 11.
I have determined I need gear set kit 43-883473A3. I counted the teeth on the gears and the main gears have 32 teeth and the pinion has 27.
I am also planning on ordering the bearing assembly 8M0103472. On mercruiserparts.com, it states if using on an older drive without a U joint shim, one must be used. Here's a link to the page: https://www.mercruiserparts.com/8m0103472-bearing-assy. It also talks about a new shimming procedure. Now, I did find on the mercury parts website that a shim is used on the newer Bravo drives. Is this something I need to worry about on mine? If so, how do I know which shim I need and does anyone have any information on the new procedure?
Thank you
Thank you
