Hi folks, I have a 1996 130 Evinrude that decided it did not want to start, i disconnected the kill wire (black w/yellow stripe) at the engine. It now will fire up.... Of course shutting it down is another issue. This engine is on a houseboat with an upper and lower helm, I have a relatively new ignition switch on the lower helm and the upper (exposed to weather) helm is probably 10 years old. I had a spare switch, so I changed out the upper helm switch and the engine still won't start with the kill wire connected. I will check the lower helm switch tomorrow against the tests I have learned from this forum. I am betting the newer switch is good..... If so, anything else I should check for? Any suggestions are welcome. Trying to line up my options early due to real limited time trouble shooting this stuff.
Ps one possibly important note; I did touch the engine power cable on the battery in reverse polarity. The battery switch was in off position, but there was a spark.. Simply wasn't paying attention. I have checked the rectifier and all seems well. It starts as long as the kill wire is disconnected.
Thanks, Scott
Thanks, Scott
