Question about Leak Testing the boat
74bayliner
I know this may be over kill.. But after refiberglass the hull, stringers and transom would it be a safe idea to just install the Engine, and outdrive to seal the transom hole, and patch gelcoat
than to just plop the boat into the water by the dock for a good 10 hours while i fish to see if there are any water leaks...
any recommendations ?
oops!
Re: Question about Leak Testing the boat
if you have done a full gut replacement......you will have gone over every inch of the hull....
you will know the hull intimately. if there is a hole in the hull....you will have painstakingly repaired it and missed nothing.
i could be wrong.....but i dont think its possible to do a gull gut and miss a hole or weak spot in the shell.
if you have any leaks at all, they will be coming from under the rub rail, or the transom /drive hole.
either of those two leakage areas are nothing that the pumps cant keep up with.
but after any restoration project.....there is a period that you intently watch these areas looking for intrusion.
Woodonglass
Honorary Supreme Mariner
Unless you just wanna sit in your boat an go fishin...fuggitaboutit!!!!!
Ayuh,.... I finish it enough to splash it, 'n go for a Boat Ride....
74bayliner
thank you all for your input. I will forgoe that afternoon than and just go fishing and back to the boat work it is ! :) I cant wait to start the grinding... got 10 more days until we close on the house than a right away the boat meets the garage for the first time
F14CRAZY
Ensign
yup...if there possible was a hole, you'd know about it
74bayliner
Ok thank you. And thinking about it now. a way i can tell if i have cracks is to put a few bright bulbs inside the boat cover it with a tarp shut the lights off in the garage and look for any glimmers of light that way i can tell where my spider cracks and little pin holes may be .. thanks fella's this forum makes life so much easier and puts my worries at ease
