beason
Thread starter- Joined
- Mar 15, 2011
- 338
I noticed on the last outing that my depth finder was reading 0.0 and blinking. I got out there today to check it out. I pulled the transducer off the mount, it was dry inside and it was kind of dirty, so i cleaned it up and tested it in a bucket. It read, although it seemed to be a little off.
I went to put it back on the mount and noticed it was loose, and when i tugged on the mount it began to break free of the hull.
I pulled it off, scrapped off the old sealant, and cleaned it all with alcohol. I used some marine sealant/adhesive and mounted the base back on the boat, I wasnt sure what angle, so i put it back the way it looked when i started. I am letting it sit overnight to cure.
So now. do i need to fill this mount with something? if so, what is suggested?
This is the depth finder
and this is similar to the transducer. Although im not sure if its exactly the same model, it is very close if not.
Thanks in advance.
Thanks in advance.
