Question About Replacing Trailer Lights.....
BoatNoobie
Yes, I'm a noob.:(
Anyways, a few weeks back, someone hit my trailer and damaged my crossmember, bunk, and bunk support.
The bunk is probably fine, but I'm replacing it just in case.
My plan is to go to the lake and launch the boat. Then work on the trailer in the parking lot....
My question is obviously, I have to somehow disconnect the wiring from the light housing. I assume I just clip them and then use butt connectors?
Or does the wire harness somehow disconnect from the light housing?
It's a incandescent housing.
marcortez
Re: Question About Replacing Trailer Lights.....
It would appear that those lights might be the "submersible" type....therefore you cannot disconnect the wiring at the lens assembly.
(if no two way connectors are used)
Clip, reconnect, using adhesive lined, shrink butt connectors. (Ancor)
You can also use a short piece of shrink tube over that connection to provide an extra measure of waterproofing.
BoatNoobie
In case anyone else bumps into this problem. I'll provide an update.
On my harness, there is a quick disconnect type connection. There's about 10" of wire off the lights until you get to the disconnect.
It was easy as pie fixing my trailer.
marlboro180
Aww, there should have been more drama!
Sorry your trailer got hit, but I am glad it was an easy fix.
lncoop
Yeah, don't you know you're supposed to give everyone an opportunity to give you a hard time?:p Welcome aboard. You'll find great advice here when something else comes up and a lot of fun the rest of the time.
