Question about Temperature gauge
zang8027
I got the boat in the driveway and I do not have a temp reading on the gauge after the engine warms up with muffs. Is there a test besides continuity that I can run to test if its the gauge or wire? I see a white wire coming off one terminal on the back, and I think a purple one (light maybe). Can I ground out a wire or something to get it to see if the pin moves?
See sig for motor info. MCM170 alpha 1
Don S
Re: Question about Temperature gauge
Take the wire of the sender (on the engine). With the key in the run position, touch the wire to a good clean ground. The gauge should peg to full. Don't hold it on there, just a touch to see if the gauge works.
It's a tan wire going to the sender.
zang8027
Thanks! I was able to get it to spike. Must be the sending unit. Dumb question but let me eliminate it as an issue - The boat does NOT have to be in the water for it to read correct?
Don S
No, but the engine has to be run on muffs and the engines temp has to be above the minimum temp on the gauge.
