question about tilt
wildcat8466
after I put tilt all the way up, in about a weeks time the tilt is all the way down. Is the tilt suppose to leak off like this , or do I have a problem, and what could cause this??
ziggy
Re: question about tilt
nope, not supposed to do that. yer leakin somewhere. follow all the hydrolic lines and look at ea. connection for a leak. could be the trim cyls. are leaking internalally too.
when ya store yer boat. ya should leave the drive down........though in this case, it seems that having it up may have put ya onto a problem before it gets worse....
wildcat8466
what kind of hydraulic fluid does it take , it looks pink, can you get it at a automotive store or only at a marina,boat place
Don S
"Pink" lube is ATF & Water mixture.
That would indicate to me a problem with the seals leaking on the trim cylinders allowing water into the system.
