Question about timing procedure, 1988 evinrude 60hp
renegade15
I checked timing according to the timing procedure thread in top secret file, according to said procedure it is 3 degrees advanced, showing 18. The full throttle advance should be 19 +/- 1 if it were running in the water, so 15 according to the top secret timing procedure math. I will of course fix this. However my question is would this have any ability to effect my middle cylinder not firing correctly at idle? The reason I ask is I can cover the middle cylinder while idling with very little effect on the engine running. Vacuum wise it is still pulling fuel out of the bowl so I don't think an air leak is the issue with being able to cover the carb. Spark is good and I have switched around the coils and plug wires to eliminate those items. Plugs are all new correct champions. So anything else?
