atx111
- Joined
- Oct 13, 2009
- 145
Had a tire go flat on my front axle the other day trying to get home. Belt had gone on the half the circumference on the outside and noticed some tread separation on the outside of the tire on the other side of the axle. But, the tread separation may have been from riding on it until I could get the rig pulled over. The tires were on about a year with around 3000 miles on them.
Got a whole new set of Maxxis tires(I'm paranoid like that), and after I changed them out, I noticed quite a bit of positive camber on the front axle, enough you can see it, on both front wheels, more on the wheel where I had the flat. The axle is a UFP 3700# torsion axle. I have to turn while I'm backing the trailer into my storage stall, could that cause the camber? I guess I need to check them after running straight for a bit.
At any rate, I'm going to have my mechanic do a thorough inspection as well as repack all the bearings and replace if needed. I just don't want to be chewing through tires every year.
My question is, what could be the other causes of this other than turning sharp while backing?
