I'm sure this will fall under the category of stupid question... I have a '85 85HP Force. I am concerned that not enough water is flowing through. There is a dual exhaust port on the upper portion of the lower unit, and a larger single exhaust port on the bottom just above the prop.. When I have it hooked up to the garden hose, there is a lot of water shooting out from the lower exhaust, and a weak/small flow from the upper dual port.
Today on the water, I noticed that at a lower speed there was a pretty fair amount of water coming from the upper ports (not a lot of force though). As higher speed there was little to none flowing from these ports. I am positive that there is a high flow from the lower, but wasn't sure if this was nromal behavior.
I did put a new impeller on last season, and it's only been in the water a handful of times (less than 12) so I wouldn't think the impeller is worn.
Any thoughts?
Any thoughts?
