ChooChooSnakeMan
Thread starter- Joined
- Dec 11, 2023
- 78
Ok, I'm not new to boats but it was always bass boats until my wife and I purchased an Ebbtide 2660 (26 1/2') bowrider last fall to make memories with our Grandkids. My wife and I finally got it on the water on May 5th for a test run before we have guests onboard. Never having a docked a boat before that didn't have a trolling motor was kind of an adventure but I'll learn, otherwise we had a great time on the water. My question / concern is that when I pulled the brass drain plug after about 5 hours on the water and 30 miles of running a couple of gallons of water came out. Not a bunch and as far as I know the bilge pump never came on (need to check to make sure the auto pump even works). Anyway we weren't in any rough water, never rained or took any waves over the bow. We didn't get ourselves in the water so no bringing water on board. I have a years warranty on this boat which expires in October. I want to be fair to the seller and not run to the service shop with problems that aren't problems but are normal. Since this is our first non fishing boat and first stern drive boat I'm not sure what is normal. It has a Volvo Penta DPS-A dual prop drive. The boat has only 100 hours on it since new but it is a 2011 model. I think I had the drain plug tight but I didn't use any teflon tape or any sealant on it, I don't know if any is required or not. The boat has an 8.1 Gi-J engine and captains call exhaust which I didn't open and use on the first outing. Should I be concerned about the water? The bellow look very good but perhaps there is a tear or leak. If so what does the bellows cost aproximately to replace? I don't want to cause any hull issues with water in the bilge if that is possible with such a small amount of water and I'm pretty meticulous with taking care of things. Any advice is welcome. I've read that in this case you can pull the boat and add water to the bilge and just wait and see where the leaks are. Is this what I should do? Another question. I had to put the trailer very deep in the water to be able to winch the boat up to the stop. I'd really rather not put the trailer in so deep so I won't have to wade out and get wet but I would have to power it on. Power loading down here for bass boats is normal but I don't know about a 26 1/2' boat that weighs over 5000 lbs. Thanks in advance for your input.
