Hey folks. Heres the scoop. Upon reassembling my motor after a rebuild, I have no spark anywhere. Ran before but poorly (could have been a million reasons why) I've tested as follows.
150 volts at low speed wire on switch box from stator (should be 200-300)
15 volts on high speed wire on switch box from stator (should be 20-90)
No voltage out to coils.
All resistance checks on stator and trigger test OK.
black/yellow wire perfoming as it should
Advance module in trash bucket next to motor
I did clean the terminals on switch boxes with a wire brush, probably shorted some terminals together (off the motor) so maybe I discharged a cap into a terminal I should not have? I also overlooked the ground wire to the stator at first but did crank the motor with it disconnected.
The mechanic at the boat shop (who I trust) says its probably best to replace both switch boxes, stator, and trigger since sometimes if any one is bad it can kill the rest of the system. My stator is crusty looking anyway, and the ground wire had been pinched flat at one point (I cut and soldered that part out) so I dont mind replacing it for peace of mind. Just hoping someone might have some insight for me. Thanks!!
Adam
1988 Mercury 150 XR4
Adam
