novicetech
- Joined
- Jan 19, 2004
- 267
Hello,<br />I hope someone can clarify my situation. I have a 1987 serial 738125 3.0 mercruiser, with a ob697871 outdrive. I had the boat on the water for the first time this weekend and discovered that after replacing the tilt trim hoses, that the reservior appears to be cracked. Now I looked on the Mercury express home page using my outdrive serial number and there is about four different pumps listed. And just the reservoir is no longer available. Then on this site I see an Arco Reservior kit that will replaces bad reservoir. Will this Reservior fit my particular motor? Question number two is, and this may be a stupid question, but is there a way on my morse controls for neutral warmup? All of the outboards that I have owned in the past have had it. Without it the boat is difficult to start. Oh one last thing which electronic conversion kit would work with my motor? I do know that the rotor button says Delco remy on it, if that helps.<br />Thanks for the help.
