- Joined
- Oct 25, 2011
- 25,262
Re: Can Someone Answer This?
Of course based on CW's experience w/ ProCraft, and his post in your other ProCraft thread, my previous post may prove incorrect about factory vs previously re-done:
Ahhh another ProCraft from the "presoldout" era. My favorite boat. 1/2" plywood is fine for all the deck work. All the ProCrafts I've done have had 1/2" from the factory. I personally don't see the need for the extra weight of the 3/4" plus it won't match what was there.
As far as leaving the cap on....that will prove to be a challenge to get a good job. It's tuff to fit the new deck in and under consoles, storage lockers, etc. And I'm not real crazy about the idea of splicing it in to "a little left" of the old deck, but your choice.
The stringers in your boat are either 2 x 6's or laminated 3/4" plywood to make the 2x stringers. Either way they are not for say "glued in", but glassed to the hull. You'll have to grind the glass tabbing loose and they should come out rather easily. I've had a few where I had to pry a little but they'll come out. Again this will be tuff with the cap on since the stringers run the full length of the hull.
CW
