Question - identifying part needed
MortenH
Hello<br /><br />I need a complete power tilt/trim unit for my 1984 115 Mercury i6 - serial 6524115. This is the "newer style" with one hydraulic ram. How can I find the part # to fit my engine. mercruiserparts.com have just the part# for spare parts, not the whole assembly. I have found one item on ebay - part# 99659A48. Will this fit my engine?<br /><br />-M-
AMD Rules
Re: Question - identifying part needed
When I look at the mercurypartsexpress site, I get part number 826729A08 POWER TRIM KIT for your motor.<br /><br />Not sure about the number you listed from eBay, other than it is replaced by part number 818186A8 which is no longer available.
MortenH
Hello again <br /><br />Thanks AMD!, but I dont think my question was clear enough - I dont have any part of the power tilt/trim. I just have one "shock absorber", and need to lift the engine with my (increasing) muscle power. In other words, I need the whole assembly. If I understand the drawings correctly, the part# above is just a piece of the assembly.<br /><br />-M-
Wiggy
Hei Hr Norge!!<br /><br />Jeg tenkte at jeg skulle snakke litt på ditt språk!<br /><br />Den er en fin motor du har der, og kanskje en dag kan jeg også eie en 'tower of power'....<br /><br />Har du søkt på både ebay.co.uk og ebay.com eller kun den ene? <br /><br />Jeg har funnet....<br /><br /> http://cgi.ebay.co.uk/Outboard-Merc...587290367QQcategoryZ15271QQrdZ1QQcmdZViewItem <br /><br />Lykke til med søket.
Kenny Bush
You should be able to get a million of them on Ebay... Just look for one 84-90 or even newer if you can get the matching wiring harness and newer solenoids. Also you will need a trim/tilt switch for your shifter.
