question on 84 75 powerhead rebuild
20hpmercury
Need some advice on an 84 75hp powerhead rebuild, particularly the direct charge pistons.
Service factory manual says to heat up the direct charge pistons with a torch lamp to 190.F to remove and install piston pin.
This does not sound like a lot of fun and how do you keep the needle bearing grease from melting out when reassembling? Any suggestions on how to best do this?
Much thanks.
