Question on exhaust flappers
1985mariner20
I have a I/O with a mercruiser 357 motor and a VP duoprop outdrive. with this combo, there are no flappers in the exhaust system. I am currently doing a complete rebuild due to the engine sucking in water through exhaust valves when it died in the ICW. My question is, Where/how would I add exhaust flappers to the system. some systems have them in the Y pipe(my Y pipe doesn't have the holes to install flappers), some systems have the flapper in the exhaust bellow between they pipe and the out drive( I would like to not have to remove my outdrive if possible). Can anyone point me in the right direction for maybe adding them in between the risers and y pipe? Any help is much appreciated!
Motor is a 2013 merc 357 5.8L 325HP
Outdrive is a VP dp-s1 "SX"
alldodge
Have any room to raise your elbows with spacers, or change to higher rise elbows?
1985mariner20
I've got some room to play with there. How high above water line do risers need to be to be safe?
