Question on fuel stabilizer?
imported_Captain Morgan
I understand that I should add fuel stabilizer during the off season to prevent varnish buildup in the engine and carb. Does this mean that I need to pour a bottle in the tank before I head in to the ramp for the last time this season so it can be in the tank and in the engine and carb?
Reel Poor
Re: Question on fuel stabilizer?
I recommend Sea Foam with every fill-up. Also recommend storing your boat with a full tank of fuel, it helps keep condensation from forming.
Avaliable at most auto parts stores.
xtraham
and with todays fuels disconnect the fuel line and run the carbs dry before storage.........and/or drain them
Boatin Bob
Yes I always put mine in before the last run so it can mix thoroughly with the gas and get through the entire system including the carb.
ziggy
yep, me too. i run stabil for the last few outings too. as state above, that way i'm hip that the stabil is mixed good and inside my fuel system when put up for the winter..... i hate winter....:(
Xtraham, you made mention of "today's fuels". Is it the ethanol that is a problem? Are the fuel lines deteriorating? Where should I disconnect the fuel line in order to run the carbs dry?
xtraham
assuming you have an outboard, disconnect the fuel line at the engine let it run until it shuts off, then do the recommended winterization, ethanol is not a problem with fuel lines/hoses regaurdless of the myths you may here if treated with the proper stablelizer,
ziggy
i used to do this too. but now have the question. while running the carb out of fuel and oil. what lubs the engine in the last moments before the carb is dry, whilst it is real lean from lack of fuel, and oil?
the drain them dry idea sounds ok though.
xtraham
there is still enough lube, how many folks run out of fuel before switching tanks while under way, when the fuel/oil mix stops so does the engine,...and the lube in the fuel is collective the fuel is not................
ziggy
i'm with ya xtraham up to
i don't understand collective.
if ya got's whatever mix of oil and fuel. when the bowl is full, the engine see's the right amount of fuel,and oil. when the bowl is almost empty, and running lean, wouldn't you be lean on oil too...
i understand this don't happen for very long before it dies of lack of fuel. but, to me it still seems at the last moment it is lacking fuel and lub....help enlighten me......:) i want to understand....
yep, i've run my 2 stoke out of fuel many times w/o ramifications....i suppose this could be the crux of the statement....
not tryin to stir up controversy. just want to undertand..
in the end, i'm still goin with stabil.....:)
xtraham
fuel oil mix passes through the crankcase and collects to the moving parts, not being burnt off internaly, the fuel mix is (sucked) into the combustion chamber and burned thus after the lubricatation has taken place
ziggy
thankyou very much. i learned something. should have known that too. but i appriciate ya spellilng it out for me....guess i'm startin the day off good with a bit of re-education.......:)
xtraham
it is still better to drain the carbs, but for those not mechanicaly inclined running dry is better than a full bowl of fuel sitting for the winter season
