I have a question on the Coast Guard certfied fuel lines. I need to know what is required to be safe to run from the Fuel pump to the Carb.
The engine is a 1994 Mercruiser 305 with Alpha 1 Gen 2. I Want to know what type of line I can run as I need to run a new fuel line. I had upgraded the carb to a 4bbl over the winter and the fuel line is a Metal line half way up, and then there is a rubber line that goes to the carb. There is a small leak somewhere in here. I want to replace the line to make sure it is all safe. I just need to know what I should replace it all with. From the Fuel pump up to the Carb.
Thanks,
Bryan
Thanks,
Bryan
