Kajun37
- Joined
- Feb 17, 2006
- 348
i have 20hp merc 1979...when i got it it had a bad coil and would only run on one cylinder.....so i bought a used one on ebay...and it worked fine, both cyls firing.....have ran it in a barrel a few times over the last couple months...yesterday i finally got to put it on a boat and was going fishing....tested it in barrel before i left and worked fine....get it in water and bam.. back to running on one cyl..same side as it was on the orig bad coil.....swapped the coil wires to see if it was a prob coming from the stator or power pack and everything checked good...so it looks to be another bad coil...
should i just buy a new one? buy 2 new coils....or could there be something that is burning that coil out?
