rhillman75
- Joined
- Jul 28, 2010
- 176
Okay here is my main question. With the motor in a 55 gallon trash can full of water, I set all 3 carb screws to 1-1/4 truns counterclockwise from seat position. I go to throttle back and forward...I understand that part. The part I do NOT understand is your suppose to adjust them while the prop is turning. So do you adjust just the top and then the other 2 the equal amount of turns in or out? Or do you adjust the top as primary 1-1/4 out then adjust the other 2 to compensate for the smoothest idle. As I have said in the past...I am a fuel-injected guy...this is a little bit out my area.
