Question on leaf plate
djmeaney
Took carburetor off for rebuilding (again) and looked inside intake manifold. I noticed a white(ish) rectangle about 1/2" wide X 1" high (see pic). I presume this is normal and something that is supposed to be there. Not that familiar with 2-stroke engines and wanted to check.
I looked at the intake manifold diagram and didn't see it listed as a separate part.
This is on a 2000 Johnson 4 HP.
Bob_VT
Re: Question on leaf plate
It is the reed valve ;) Very normal in 2 strokes.
Bob_VT
If you look at the shop evinrude it is in the intake manifold picture.
djmeaney
Bob,
Thanks, I'll leave it alone!
Guess I'm showing my ignorance of two-strokes.
Bob_VT
You are just showing your learning curve ..... not ignorance ;)
You should see the reed valves in a V-4 or V-6 :)
